Need advice about a build list
This is the list that is on the TBSS, has 107,000 on body but motor and trans have about 10,000
Want to know how reliable this SUV would be and if i could get it for 18,000 would that be a good price.
Engine built by Mercer Machine and Performance/DK Motors
Tuned by Justune
P1SC procharger on 8lbs
HOB bracket and intercooler
polished crank shaft
balanced rotating assembly
Mahle Forged Pistons/file fit rings
double roller timing chain
PCM of NC oil pickup tube relocation
ARP rod and head bolts
Custom ground blower cam (can give specs if interested)
3 angle valve job
Comp Trunion upgrade
Comp Cams Ultra Gold Aluminum Rockers
Harden pushrods
Trick Flow Gen X 220 CNC heads w/titanium retainers
Holley tall valve covers
Felpro gaskets
Custom Catch Can
NGK TR6 plugs
degree cam
melling high volume oil pump
keyed crankshaft for Procharger pulley
ground valves/resurfaced heads
Bosch 60# injectors
Aeromotive 340 fuel pump
Taylor wires
Aluminum radiator with twin electric fans
PCM of NC transmission cooler
K&W rear shocks/coilovers in front
Sphon adjustable upper/lower rear control links and pan hard bar
FTI 3200 Stall with billet front plate and RPM 4l70e Level 6 transmission
Resonator cut out/straight pipe in place
Borla XR1 muffler
Brand new Hankook Ventus tires
Tuned by Justune
3 angle valve job
Harden pushrods
Felpro gaskets
Custom Catch Can
NGK TR6 plugs
degree cam
Bosch 60# injectors
Taylor wires
Borla XR1 muffler
jik294
Oct 21, 2016 12:44 PM
