TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
interesting trans temp...
Old Feb 5, 2009 | 08:53 PM
andrew383's Avatar
traveling mod
Default interesting trans temp...
i was headin back from tx a few weeks ago and was pulling about 4K behind the ss drivin about 80mph and the trans got rather cold.it got down to this temp after about 20 miles of driving......good?....bad?....thoughts............ .......
edit:forgot to add i do have a trans cooler on it.
[ note the trans temp ]
Old Feb 5, 2009 | 08:55 PM
bluecajun5.3's Avatar
11 Second Truck Club
Good!
the converter was in lockup and wasn't generating any heat.
Old Feb 6, 2009 | 01:50 AM
Mr. P.'s Avatar
I would get the heat up a little, to at least 130. When you added the cooler, did you completely bypass the radiator? If so I would consider putting the external cooler in series with the factory air/water ATF cooler, to put some heat back into the ATF. My trans always grips/shifts best at a temp of 155-160. I would not worry about the shifting if you are using synthetic ATF, but regular Dexron-III does not flow right at those temps.
My 2-cents.
Mr. P.
Old Feb 20, 2009 | 04:06 AM
Parke10's Avatar
am i reading that wrong or does it say yer IATs are at 12*F?
Old Feb 20, 2009 | 11:00 AM
andrew383's Avatar
traveling mod
nope its right!! it was freakin cold outside lol
Old Feb 20, 2009 | 03:46 PM
Parke10's Avatar
lol i dont think it ever gets colder than high 20's outside here let alone cold enough to have a IAT of 12
TAPyvehc93
Jul 23, 2017 10:54 PM
thunder550
Oct 8, 2015 04:53 PM
brandon6.0
Aug 7, 2015 11:22 PM
black6spdz
Jul 16, 2015 01:32 AM
