TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Difficulty removing clutch fan
Old Mar 15, 2021 | 10:27 AM
thebrain's Avatar
Default Difficulty removing clutch fan
07 saab 97x 5.3i
Can’t hold water pump from turning this water pump is smooth on front there aren’t 4 bolts on the water pump pulley. there aren't any holes in the pulley either.
Here is the tools I got from advance auto no one there knew how to use these tools.
The big wrench isn’t an exact fit on the clutch fan nut there’s a possiabilty of rounding it off if it’s on real tight.
I'm starting to think I have the wrong tool if I remember correctly it's called a spanner wrench which I've never used either.
Please need advice to lock down waterpump pulley.thanks for any advice.
additionalley are the 6 cylinders fan the same as the L33 v8 5.3litre engines fan? this fan is kindof pricie to replace. I may be able to recycle from the junkyard.
Old Mar 15, 2021 | 02:12 PM
thebrain's Avatar
been watching videos I'm not wanting to destroy anymore stuff so that rules out vicegrips holding the pulley.
not interested in beating on the nut w/ a chiel then ruin the water pump no thanks.
maybe a oil fliter wrench mite hold the pulley?
this is a new vehical to me so I don't know much about it.so feel free to explain to me that's if you feel like it.
Old Mar 15, 2021 | 02:29 PM
RedXray's Avatar
100% Redneck
With the belt tight... I used a 15" adjustable wrench and smacked the handle with a hammer to remove the fan. Loosened up first try.
Old Mar 15, 2021 | 02:46 PM
thebrain's Avatar
mite have to get out a hammer hate to break more stuff. I assume the sudden impact of hammer is acting as a impact. I believe I've got the wrong wrenchs.
have you heard of a spanner wrench? I maybe mistaken.
I must be overlooking something.
BTW the truck sound clips sounded awesome you strike me as someone thats drives like that everyday when applicable.keep up the good work.
Old Mar 15, 2021 | 04:21 PM
RedXray's Avatar
100% Redneck
Thanks I drive the truck about twice a week weather permitting.
Check out Youtube there are many different ways of removing the fan. This is the method I used and it worked well for me. If you think there may be some corrosion it may be a good idea to hit the threads with some penetrant oil and let it soak a bit, then wipe clean before trying.
Old Mar 15, 2021 | 04:47 PM
TXsilverado's Avatar
Smack it with an air hammer. it will **** you off how easily it comes off. You're welcome
Old Mar 16, 2021 | 07:38 AM
zz454Chevelle67's Avatar
I do it the same as RedXray, easy and has worked everytime.
silverado2003
Nov 24, 2012 12:13 PM
GMC5.3
Apr 2, 2011 11:17 PM
SUPERCHARGE
13
Jul 17, 2010 04:07 AM
SUPERCHARGE
24
Feb 21, 2010 03:30 PM
Ruffrider5.3
Jul 2, 2005 09:17 PM
