Sorry it took so long to reply schools been hell lol My truck is a 03 z71 i have 285 75 16 rite now and there is no rub and im bout to put torion keys and a 2inch block and tryed putting my buddys 35 12.5's on my truck and there just ant no way 35's will fit with just wut im planing to do to it. THanks to everybody for helpin me out. I think im just going to go with 33 12.5 18's
3" body lift and some T-bar crank you will clear 35's with ease. my buddy had a 3" BL and ford t-keys cranked and hes running 36's with 0 probs. body lifts are fine just make sure you get the gap guards to cover the spaces between the frame. i have one on my truck and nobody can really tell since i have the gap guards.
Zach-
What brand and model of tire are your brother's 315/70's on the maroon truck ??? |
Where do you get the gap gaurds from ? And did you put the body lift on yourself i have heard there easy to do?
pro-comp makes a seven inch kit for 2WDs for 35s! i dunno bout 4WDs. If its for a 18' wheels u r prolly going to have to go metric on the tire size! call 4wheel parts and ask.
matt p.s. i used to work at discount tire! |
It is 18' wheels but i think im just going to try 33's for now and prob buy a 6 inch lift in the summer sometime. But even with a 6 inch lift are you still going to have to cut anythang for 35's?
Originally Posted by tanz45
(Post 4382283)
This is what I know fits from my own experiences and will leave you without rubbing the tires. Very minimal if you do. And won't leave your truck looking stuffed.
99-07 1/2 1500 4wd 2'' Leveling Kit -285/75/16 (33's) on stock wheels 3'' Body Lift -285/75/16 (33's) on stock wheels or up to 8'' wide with slight T-bar crank 4'' Suspension Lift -285/75/16 (33's) on stock wheels or up to 8'' wide 6'' Suspension Lift -315/75/16 (35's) up to wheels 8'' wide 6'' Suspension Lift w/ 3'' Body Lift -315/75/16 (35's) up to wheels 10'' wide -37's on wheels up to 8'' wide Generally you are right there, it all depends on how much back spacing you run, I had a 3 inch body lift ONLY with 315/75/16s on stock rims and I didnt rub at all even if I had the wheels turned all the way and hitting bumps |
Well my new wheels have a back spacing of 5 5/8's and they are 9' wide so i guess ill have to stick to 33 12.5's right?
Kumho makes a 35x12.50x18 i have these in a 33 on my truck pics in my sig
I really like those kumhos how much do they run you?
