TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Wuts needed for 35 12.5 on a 1500????
Old 01-22-2010, 02:46 PM
Y@ BoY p@Ul's Avatar
Default Wuts needed for 35 12.5 on a 1500????
Wut will i have to do to fit 35 12.5 18's on my 03 silverado ?
Old 01-22-2010, 03:16 PM
BIRCHZ71's Avatar
welcome to pt......what yr truck? 2wd? 4wd? need some info
Old 01-22-2010, 03:20 PM
BIRCHZ71's Avatar
Also im not sure if anyone makes a 35/12.5/18
Closest thing I know of for a 18" wheel is a 325/65/18 which is roughly 34.9" tall with and 13" wide.
Old 01-22-2010, 03:25 PM
gblauf's Avatar
6 inches of lift, 2 or 4 wheel drive. You could also do 4" suspension lift and a 2-3 body lift. I think body lifts are ugly but they are cheap!!
Old 01-22-2010, 03:37 PM
BIRCHZ71's Avatar
I can tell you if you are 4wd a 4 in suspension lift if plenty for a 35. I have factory keys cranked and a 3 inch block in the back(1 inch lift) and run 34's that are 13 inches wide with zero issues. Also if your 4wd, a small bodylift would do the trick.
Old 01-22-2010, 04:26 PM
00Silv4.8's Avatar
you may even be able to get away with a 2" lift and hacking on the front bumper. Rears should fit no problem with 2"+ lift
Old 01-23-2010, 10:46 AM
zachm89's Avatar
I had a 3" body lift and some bushwacker cutout fender flares on my 03 z71...it fit 35x12.5's with no rubbing at all. Although, for the price of the body lift, those flares and all the labor, i would just go with a 6" suspension. you dont NEED to, but its the route that will look the best in the end.
Old 01-24-2010, 09:11 PM
Zach79Z's Avatar
3 inch body lift if its a 99-06 4x4 will fit a 315/70 which is equvilent to a 35x12.50. And i believe its mickey thompson that a buddy of mine has on his truck that is a 35x12.50
My brothers truck. 3" body lift and 315/70s
Old 01-27-2010, 08:05 AM
tanz45's Avatar
This is what I know fits from my own experiences and will leave you without rubbing the tires. Very minimal if you do. And won't leave your truck looking stuffed.
99-07 1/2 1500 4wd
2'' Leveling Kit
-285/75/16 (33's) on stock wheels
3'' Body Lift
-285/75/16 (33's) on stock wheels or up to 8'' wide with slight T-bar crank
4'' Suspension Lift
6'' Suspension Lift
-315/75/16 (35's) up to wheels 8'' wide
6'' Suspension Lift w/ 3'' Body Lift
-315/75/16 (35's) up to wheels 10'' wide
-37's on wheels up to 8'' wide
Old 01-27-2010, 09:25 AM
Zach79Z's Avatar
That maroon truck is my brothers its a 3 inch body lift with 35s and doesnt rub at all
Quick Reply: Wuts needed for 35 12.5 on a 1500????
