TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Would i have to re-gear
Old Apr 22, 2012 | 01:04 AM
oubowtie06's Avatar
Default Would i have to re-gear
I have a 2011 silverado Z71 and i currently i run the 5 inch rough country lift kit and i was thinking about adding a 3 inch bodylift to my setup. If i did that but still ran my 33's would i have to re gear?
Old Apr 22, 2012 | 01:16 AM
pewterliftedz's Avatar
first off why would you run an 8" lift with 33s??? secondly you only regear for tire size, not lift..
Old Apr 24, 2012 | 07:08 AM
rjwz28's Avatar
Man Motor club
I run 33s with a leveling kit only and have never rubbed (stock wheels). An 8" lift will clear 35s without any problem. You should have 3.42s because you have a Z71; personally I would swap to 4.10s with 33s since you have 3.42s. I would like 4.10s on my truck, but I already have 3.73s and that isn't enough of a bump, plus my 6.2 makes up for a bit of the loss in gearing. In short, 33s go well with 4.10s, 8" lifts go well with 35s, and 35s go well with 4.56s.
Old Apr 28, 2012 | 10:06 AM
LS1TRUCKGUY's Avatar
i have a 6" lift on 35s with 4.10 gears. IMO it needs 4.56 gears at least. i would throw some 4.10s in there with 33s
willhorne22
Apr 12, 2018 09:14 AM
Oobray
Aug 2, 2015 01:13 PM
blackseven
Feb 11, 2015 11:19 AM
speedfreak391
11
Apr 30, 2013 03:42 PM
