Tune after transmission rebuilt
I recently bought a 05 Silverado 1500 z71 cc and I rebuilt the transmission and I was wondering if I had to tune the truck since I added corvette servo and tb i6 stall to it? This is the kit
Overhaul Kit (Includes all the seals, gaskets, o-rings required for year range. Contains pump wedge style seal) Deep 1-Piece "No Leak" Style Oil Filter Raybestos Stage-1 Red Plate Performance Clutch Module Molded Rubber Piston Kit Upgraded Corvette Style Servo Complete Steel Plate Module ProSeries Kevlar 2-4 Band Thrust Washer Kit w/ Common Selectives Transgo Zinc Coated HD Separator Plate New Torrington Bearing Kit Upgraded HD Style Input Sprag A & B Shift Solenoids Upgraded Heavy Duty Sun Shell Full Bushing Kit |
In a perfect world yeah it could be tuned for the converter changer but it's really not that much bigger than stock. It may shift and lock perfectly fine.
Vette Servo doesn't need to be tune for on a stock transmission. |
Ok thanx
