trailer brake controller?
im in the market for a trailer brake controller, and when looking at them, they say plug and play with factory towing package, i dont have a factory towing package, but i bout one of those 7 pin adapters that plugs into the big round plug that was above the spare tire, and was wondering if a trailer brake controller would work with my setup.
You should have all the hook ups since you have the 7 pin plug. Like swift said all you need is the controller and the wire harness for your year of truck.
I wouldn't recommend getting anything more then a basic digital controller. Honestly an analog one would be just fine but digital isn't that much more($20 or less usually) and it has a bit more adjustability.
I run a draw-tite activator 2 controller in my duramax. Its Digital. Goes by .5 increments and can handle a 4 axle trailer. $80 for the controller. I had a local trailer shop install it with the plug and play harness for $95
ok, so im looking for something cheaper, and can be removed easy. i only plan on towing this trailer 2-3 times, only to get a project car to the exhaust shop and to my work to perform an alignment. any recommendations for that?
I have one I pulled off my truck that plugs into the factory setup that I will never use. Was going to sell it, make an offer if interested. Will let it go cheap.
https://www.dropbox.com/s/ltq5my230s...%2031%20PM.jpg
I see you added hydro-boost from your build thread, add SS brake lines and done. I would say GMs factory brakes are good for a RCSB.
I would say if your towing anything that needs a brake controller, your 4.8 RCSB would mostly likely be beyond its factory recommend limits. However I have towed more than my max limit
Not positive. Will have the wife try and get a part number so I an look it up. I am away for work right now. Came off an 04 so I would think it would but not sure
