Traction differences 275 to 305 tire?
High on diesel fumes
I currently have 275/55R20 Toyo Proxes ST on my truck. Looking at new tires in the next couple of months, and saw that Nitto 420S is offered in a 305/50R20. Anyone gone from a 275 to a 305 and can share experiences with traction improvements? I am traction impaired in 2wd in this truck, it'll blow the tires off at 55-60 mph without breaking a sweat. The 305s look to be about $35 ea more than the 275s, and I may have to do some trimming up front to make them fit, so I'd only switch if it would be a decent enough increase. Experiences?
thunder, i was going to try out the 305 myself. bought some cladded wheels so ill need new rubber. but i was going to run their 285 up front.
also, where at in phoenix are you? i think ive seen that black truck rolling around.
the best bet for a 20" wheel is the nitto 555R. every other tire will suck for traction, and the 555r wont be perfect since you're on a 20" wheel.
once you hit a certain performace level in a truck, a drag radial is the only help you'll get. I've tried just about every "sport" tire out there. they all suck.
Wait, so eventhough you have 4wd at the touch of a button, this is still an issue? I hate being 2wd. As mentioned, throw some big MT drag radials on there if you want traction. They'll still spin on the street given enough umph though.
i couldnt imagine have a diesel and its torque
Ok, I'll stick with the 275s then. Thanks.
I had 275/55R20 tires on my truck and changed to 305/50R20's Nitto 420s. My truck definitely hooks way better with the 305's. My 275's were pretty much bald though so that probably plays in to why they wouldn't hook at all. I have no way of comparing new 275's vs 305's because when the 275's were new I was stock and now with the 305's I've got a turbo.
I didn't have to trim anything to get the 305's to fit though, I just had to crank up the torsion bars a little. IMO I don't see how a 305/50R20 wouldn't hook better than a 275/55R20. They are taller with more sidewall, wider, and unfortunately heavier. The only negative I have for the 305/50R20 is I feel like I wish I had 4.11 gears instead of 3.73's now.
Here is video of me with the 275's. I can't do this with the 305's now.
