TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Thinking about lifting?
Old 05-15-2010, 04:10 PM
Import Moderator
beastmode's Avatar
Ya, you should be able to get away with a 35 with 18x9s and a 7" kit... I don't think that grey GMC had to trim to fit his setup.
But if you are dead set on lifting and you plan to leave it that way... another thing to consider is just going 10" right off the start. A PC 7" is going to run you from $1,400-$1,700 depending on what shocks you get and where you get it from... plus a 3" BL which I haven't really seen for under $400ish with all the bumper brackets and gap guards... so right there you are most likely looking at $2000+ for 10". A full throttle 10" could probably be had for around that same price and you won't have 3" of frame hanging out lol... just something to consider.
Old 05-15-2010, 07:29 PM
onebad03's Avatar
you said 18x9...what about a 20x9? i was looking at some wheels and i see -12 and -24 offset? if my math is right the -12 is the 4.5 backspacing?? RIGHT?
Old 05-15-2010, 08:08 PM
Import Moderator
beastmode's Avatar
ya wheel diameter won't really play a factor... its width and offset that can get you in trouble. your math is correct... you would be fine with 20x9 (-12) and 35s.... -24 is 4.5" on a x10.
the 7" PC with 20x9s and 35s would look sick man. I def don't blame you for wanting a 35" tire with 20s... the thought of not having alot of sidewall and wheels that stick out passed my fenders scares me a little with curbs. Might have missed it, but what wheels are you thinking? I am a big fan of XD Badlands, these are 20x9s with Toyo mud 35s... sorry its a nnbs
Also, any plans to regear?
Old 05-15-2010, 08:45 PM
onebad03's Avatar
yeah i love the XD badlands too. not really looking for a certain wheel just something simple and clean. as for gears i already need a new transmission pretty soon so im going to order a performabuilt level 2 and i had planned on getting a circle D restalled TB stall(3000-3200) and planned on a tru trac and 4.10's. if i lift it i will more than likly keep it lifted. how would a stall in a lifted truck act? would 4.56's be better for the 35's? fuel economy isnt that big of an issue but i would like to keep it in the double didgits if i can.
Old 05-15-2010, 09:08 PM
Import Moderator
beastmode's Avatar
Ya for 35s I would def go 4.56s+... I ran 4.10s in my Sierra with a 30" tall tire. Truetrac is a must! Look at Rons Machining Service and you can save yourself a little $ with buying one of his package deals. The gear will make up for you having a stall too, if I ever decide to put my 02' back together I will let you know exactly how that setup runs lol... I have a TR224 cam, SST3200 and the PC 7" kit
my turd as it sits
Old 05-15-2010, 09:40 PM
I have a gauge for that
Atomic's Avatar
i have 35s, 2600 stall, and 4.56s
having a higher stall torque converter sucks offroad, but otherwise its great. the 4.56s definately help the 35s but since ive added the blower I feel like I have too much gear and 4.10s would be more appropriate.
Old 05-15-2010, 09:45 PM
Import Moderator
beastmode's Avatar
I could def see the 4.56s being overkill with a power adder
Old 05-15-2010, 09:56 PM
onebad03's Avatar
I wont have any money left for a power adder when im done so 4.56's it is!
Old 05-15-2010, 10:16 PM
Import Moderator
beastmode's Avatar
ya be ready to drop $4.5k for lift, wheels, tires and rearend
also alot of guys like to shop around and try to get a good deal on wheels from one place, then another deal from tires from a different place... don't rule out trying places like 4wheelparts or NTW for everything as a package deal... tell them your gonna be dropping some decent money and to work on a price for ya. shop around ALOT and ask ALOT of questions bro
Old 05-15-2010, 10:32 PM
onebad03's Avatar
yeah i was going to see if i could maybe come across some used wheels in good condition and buy everything else new. one last question, whats going to be a better lift? the drop down type like the fabtech or this one? http://performancelifts.com/cgi-bin/cart/CST0006.html
Quick Reply: Thinking about lifting?
