Is there such a thing as a 4WD spindle lift
10 Second Club
I always see just 2WD spindle kits. Is there such a thing as a spindle lift for 4x4's. I am currently lifted with ford keys and an add-a-leaf but would like to get a little higher. Is a drop crossmember style kit my only option? Thanks.
I put on a Rough country non torsion drop kit and it came with spindles.
Really nice kit but you cant use lifted keys with it. Pretty easy kit, took me and my dad about 10 hours total from pulling the truck in and pulling it out including time to trim the valance and get a decent line up on it.
I think he's just talking about just lift spindles like the 3" rough country spindles for 2wds... The answer is no..
Anything over what you have now is your gunna need a body lift or and susp lift that drops the diff and crossmembers
no you can not lift a 4x4 truck with spindles, some lift kits come with different spindles (knuckles)to mount the upper ball joint and upper control arm in the factory location and let the lower control arm hang lower but thats not whats doing the lifting. 2wd spindles can lift due to the fact that there is no CV shaft that has to come thru the spindle and connect to the hub which is connected to the wheel, 2wd lift spindles just lift the truck by lowering the spindle shaft down making the wheel mount lower on the spindle lifting the truck up. hope i did not losse you lol good luck!
GXPJAY
Nov 5, 2015 06:49 AM
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
