Steering stabailizer on 03 Z71
I have a gauge for that
Their purpose is to dampen bump steer, which happens when you hit uneven surfaces and a decent speed, like offroading in a field. To put one on a lifted truck that stays on the road the majority of the time just because it is lifted is pointless. Unless you like the look. If you install one because you think you need it for anything other than bump steer then all you are doing is covering up an underlying problem with the tires or other steering components.
As they have stated above the fabtech stabilizer is the way to go. Even if you don't drive alot off-road it helps with wear and tear and also it helps to prevent that (chicken chaser effect) a truck sometimes gets on rural roads or the interstates where semis have worn grooves in the highway.. 50 bucks to save hundreds on front end parts should be enough reason! Just get the single shock stabilizer though. No need for a double if you have no plans on lifting.. Hope I could help!!
03, 1500, 2003, fabtech, hand, install, instructions, performance, pic, pics, ranch, silverado, stabilizer, steering, z71
