Thanx man that's great I'm gunna try some in my truck .. wish I would have known this along time ago. Do you 4wd launch with it sitting like it does or do you decrank it?
Bumpers you ever get em put in on your truck? I'd like to see if they run on a 6" NTD like yours
4 Attachment(s)
Posted this up on GMFS, thought I would post here for anyone curious about the NNBS axle swap for lifted NBS trucks. Big thanks to sharpshooter for the discovery.
The truck (2000 Silverado Z71 on 33's) Attachment 106270 Old axles: Attachment 106271 New NNBS axles from Cardone (about $40 each from RockAuto), note the much improved CV angle: Attachment 106272 NBS old axle with 1 7/8" spacer vs NNBS axles Attachment 106273 Took about 2.5 hours working slowly but with an impact. Pretty easy swap. I did have to disconnect the bottom of each shock and swing it out to fit the old axles out from in between the shock and sway bar end link. |
How Long were your axles lasting with the spacers? that angle was brutal!
tag, mine last 9 months before boots rip in my 04. going to try the part number ya'll posted. maybe it will work for me.
Originally Posted by Turbo09
(Post 5186972)
Is that just a TB crank TXTahoe, or TB crank and a lift kit?
Originally Posted by pewterliftedz
(Post 5187144)
Need to replace the pitman and idler arms and get it aligned before it's driveable, the alignment is way off. |
what year are you using for the new axels? I'm guessing different than a 04? or are the new ones longer than the 04's?
Originally Posted by TX Tahoe Z71
(Post 5187152)
Fabtech lift kit and looks like a bit of a crank. I need to decrank it, looks a bit extreme.
Originally Posted by BigDaddy0381
(Post 5192222)
