TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Need tire help asap!
Old Sep 10, 2010 | 12:54 PM
Dark Halo's Avatar
Default Need tire help asap!
My truck has 3" worth of lift up front and 1" in the rear, it is an 08 Z71 with factory 18s. I'm trying to choose between tires and have hit a stump. I'm trying to choose between Cooper Zeon Ltz 275 70 18, or Goodyear wrangler duratrac 295 65 18. The coopers are about 350 cheaper and I'm not sure if the 295 would rub or not. What is your thoughts what tire should I go with? Will the 295s rub?
Old Sep 10, 2010 | 10:19 PM
Dark Halo's Avatar
Anyone? I'm leaning toward the goodyears I just don't want a tire that will rub
Old Sep 11, 2010 | 01:37 AM
jg53's Avatar
if you go to a discount tire they will test fit the tire for you, but i am not a fan of the cooper zeon ltz's
Old Sep 11, 2010 | 01:56 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Good luck with ever getting the Cooper's to balance well. They have always needed LOTS of wheel weights to balance, even if you find a shop that does know how to road-force balance. You're better off taking your chances with the Goodyears, which have Kevlar, which is known to flat-spot after being parked for 5-6 hours. But at least they will smooth out after the first 5-6 minutes of driving......
Old Sep 12, 2010 | 10:38 AM
blacklung's Avatar
you can fit a 33 on that truck with the lift. Here's a pic of mine with just a 3" body lift now and 305/55-20 Cooper Zeon LTZ
and by the way I am trying to sell these tires and wheels.... I have 4 tires and wheels, and 2 more seperate tires if you're interested because 1 on the truck needs to be replaced. If interested PM me
Old Sep 12, 2010 | 12:51 PM
Dark Halo's Avatar
I like that set up
Old Sep 15, 2010 | 04:13 PM
Razorback Randy's Avatar
Get Cooper STT tires they are awesome. They took very little weight to balance, had virtually no road noise, looked cool, worked very well off road or on, and I had 20,000 miles on mine and they still had a lot of tread left when I sold the truck.
Old Sep 15, 2010 | 08:43 PM
BigKID's Avatar
I am running a 275/60/20 Cooper LTZ (33") on my Tahoe with only a slight torsion bar crank up front to level it out with only slight rubbing on the plastic inner fenders. I have had the tires for ~30K miles and have been happy with them.
Old Sep 25, 2010 | 08:45 PM
Fan45acp's Avatar
I have a Rough Country 2" level running Cooper Zeon LTZ.They balanced fine with very little weight.They ride very smooth and are quite for a A/T type tire.
Old Sep 27, 2010 | 08:20 AM
Dark Halo's Avatar
I ended up with Cooper st's for now. I'm just going to have to bump to a 20 in rim to get what I want.
