TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Longer shifter stick
Old Mar 7, 2007 | 10:04 AM
PMCSPIDER's Avatar
Default Longer shifter stick
Does anyone know if you can buy an after market shift stick (manual transmission, not 4x4 shifter) that is 3" longer than stock, for vehicles that have a 3" body lift? Its that big of deal, but, if it was a bit longer it would be easier to drive. any thoughts?
Old Mar 7, 2007 | 12:24 PM
UnrthdxDream's Avatar
hmmmm you could always weld up your own! other than that i would say check out b&m's website... they might have some...
Old Mar 7, 2007 | 12:32 PM
beastmode's Avatar
Import Moderator
when i had my body lift on my old truck i just left it the way it was, chevys sticks are long to begin wit so it was kinda nice cause it almost lowered it a lil... i dunno wit fords though, id say your best bet is to try to make your own bracket, a buddy of mine who had the same truck as my old one cept his was a 4.8 5spd said his body kit actually came wit an ext... only prob was since your usin the shifter so much he said every so often he would have to take the boot off and tighten the bolts, so w/e it is if you find something id weld that thing up. what kinda body lift do you have PA?
Old Mar 7, 2007 | 07:21 PM
mwalls54's Avatar
Need More N2O Mod
most body lifts come with a extension for the shifter. you can probably contact PA and see if they have something if yours didnt.
Wolftrk99
Dec 3, 2015 08:12 PM
g6t6o
Sep 26, 2015 10:57 AM
97_ek
Sep 23, 2015 09:16 PM
GM1697
Sep 22, 2015 09:54 PM
