TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
leveled my dd
Old 07-31-2010, 01:28 PM
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
Originally Posted by andrew383
Most 285's run around 32.75" tall and the 295's run around 33.25"..The 305/70 runs 33.75"..Hope this helps
hmm maybe ill do the 295s right between the 285s and the 305s
Originally Posted by fastlt1
What are your fender measurements now and what size tire are you running?
39 inchs all the way around ive got 245s on it right now
Old 07-31-2010, 02:16 PM
12 Second Club
fastlt1's Avatar
Mine is 37 up front and 38 in rear with 265s. I know when I crank mine up to 38 up front everyone said my angles sucked. You are cranked 1.5 higher. Your angles must really be bad.
Old 07-31-2010, 03:07 PM
you speaking of the cv angles
Old 07-31-2010, 07:55 PM
12 Second Club
fastlt1's Avatar
CV angles looked bad on mine. I think the 295/75r16s are taller but skinner then 305/70r16s.
Old 08-01-2010, 09:25 AM
traveling mod
andrew383's Avatar
Do you have fender flair's on yours?? That will make a measuring difference..
Old 08-01-2010, 06:35 PM
12 Second Club
fastlt1's Avatar
Didn't think about that. I'll have to check how much lower they hang down. I thought they came straight out at the bottom.
Old 08-11-2010, 09:09 PM
Jeteys5.3's Avatar
how did it affect the ride?
Old 08-11-2010, 09:38 PM
traveling mod
andrew383's Avatar
With the swaybar removed on the silvy i cant tell a difference between it and the stock height tahoe ..
Old 08-11-2010, 10:32 PM
it seems to ride alittle stiffer then stock height but nothing bad at all i havent put the body lift in yet im waiting on tires first. pretty sure im goin to run 305/55/20s
Old 08-12-2010, 06:13 AM
tdrumm's Avatar
I'm at 38 in the front with 265s and I wouldn't go any higher. I've got about 1/2" between the bump stop and UCA.
In the first leveled pic, his LCAs look a lot steeper than mine.
Quick Reply: leveled my dd
