-   TOWING & OFFROAD PERFORMANCE (https://www.performancetrucks.net/forums/towing-offroad-performance-168/)
-   -   How much lift? (https://www.performancetrucks.net/forums/towing-offroad-performance-168/how-much-lift-381371/)
Country Boy 12-24-2006 11:27 AM
What is the "trimming" that people talk about? What are you trimming?
ramair383ci 12-24-2006 12:53 PM
Depending on the size of the tires or the offset of the wheel will also depend on what you trim. In my case I would have to trim the front bottom corner of the bumper in other cases the air dam if your truck is equiped with one. Since I'm going pretty big I also have to trim the bottom of the back fender, a little bit of sheet metal between the lip of the fender and where you would mount the nerf bars or running boards. Hope this helps.
Country Boy 12-24-2006 12:55 PM
So you actually have to trim metal panels. my 04 has the front air dam. Interesting.
ramair383ci 12-24-2006 01:08 PM
Well like I said I do because I'm going to be running 36x15.5x20 on a 10 inch wheel with a 25mm offset. I have a 6 inch lift or 4-3/4" some say with ford keys so in order to tuck does baby's in those fenders I have to do some trimming. In my case the trimming will not be seen because I'm planning on putting some bushwaker pocket fenders.
