TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
HD Height?
Old Apr 25, 2007 | 08:34 AM
wayland1985's Avatar
Default HD Height?
Where do the HD silverados get their height? Is it body lift, or just from the beefier suspension?
Old Apr 25, 2007 | 09:11 AM
beastmode's Avatar
Import Moderator
built in 2" body lift into the frame to accomodate the Allison Tranny
Old Apr 25, 2007 | 02:15 PM
That's what I thought.... Now what problems do I run into with a body lift?
Old Apr 25, 2007 | 02:20 PM
RandomHero's Avatar
So you're saying that HD's are 4.5" taller from the factory than a z71? Not trying to be a dick, but that isn't correct.
They don't have a "build in body lift". Hence why when you buy a 3" HD body lift there aren't already pucks in there.
They are about 2-2.5" taller than a factory z71 because the frame is physically 1.5" taller and because the HD leaf spring pack is beefier.
Old Apr 25, 2007 | 02:22 PM
RandomHero's Avatar
You won't run into any problems with a body lift. My buddy has a 2002 crew cab hd with just a body lift and 315/70/17's and he hasn't had a single problem in 3 years and 75k miles.
Old Apr 25, 2007 | 03:44 PM
beastmode's Avatar
Import Moderator
no no your right, that was wat i meant, a frame lift, im sorry i said body lift. if you measure the frame of a hd compared to a light duty it is as random hero said taller like it has a built in FRAME lift like i meant to say lol. that is so your tranny tunnel aint crushin your tranny... and more reinforcement i would imagine. also as far as suspension goes they do have better springs and such so im sure that would raise it a little to as stated
you would be fine with a body lift
Old Apr 25, 2007 | 03:54 PM
RandomHero's Avatar
Ah ok, no worries. I was kinda like when you said they already had a 2" body lift stuffed under there
Old Apr 25, 2007 | 05:26 PM
rpav's Avatar
i have a 3" body lift with a CST 9-11 Suspension Lift on an HD. No problems whatsoever
TA63
Mar 29, 2016 04:38 PM
BCraven1018
Nov 2, 2015 07:18 AM
iregret
Sep 10, 2015 09:00 PM
Skip Fix
Aug 25, 2015 05:05 PM
1979rs/z28
Aug 24, 2015 08:43 AM
