TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Front diff gear swap
Old May 15, 2006 | 08:02 PM
CHUCK427's Avatar
Default Front diff gear swap
I was wondering if anyone has ever changed the front ring & pinion on the GMT 800 platform (1999 to 2006 Tahoe, pick-up, Escalade, etc...). I need to install 4.11 in a Tahoe project and was looking for some help.
Am I better off changing gears or the whole assembly?
Is it harder to set backlash up front because of the split case design?
I was considering just swapping the assembly, but they seem to be pricey in the salvage yards $700 - $1250 for a low mileage/recent unit.
Any help and/or suggestions will be much appreciated.
__________________
Old May 16, 2006 | 10:32 AM
mwalls54's Avatar
Need More N2O Mod
I have heard a few people swaping gears with no problem. If you were to just swap units out, I would go with a 2500 that way you have more beef to it.
Old May 18, 2006 | 09:43 AM
bigredexpress99's Avatar
I thought the 3/4 and up trucks used a different front axle mount design, so using it in a 1/2 is not an option. You might finagle one in there with some custom work, then on to custom axles.....yeesh. As for the first ?, finding a used front axle might be a better choice. Maybe cheaper too. I know GM gears arent cheap..........
Old Jun 7, 2006 | 09:23 AM
m7 rocket's Avatar
So what did you finally decide to do about your gears? I am curious as I may be changing out front gears also from 4.10 to 4.56
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
CammedZ71
Aug 2, 2015 01:44 AM
Ketis
Jul 23, 2015 12:37 PM
mrgrim
Jul 8, 2015 08:12 AM
