TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
cranking torsion bars
Old Feb 12, 2007 | 10:51 AM
  #21
beastmode's Avatar
Import Moderator
lol **** i was actually gonna say to you, the teflon chambers would be sick on your truck, i love those wheels, they look so much like the HD wheels
Old Feb 12, 2007 | 01:58 PM
  #22
fake_usa's Avatar
Originally Posted by 04BlackGmc
not if you dont crank alot, i have 3" longer shocks.
what shocks do you recommend?
I replaced my stockers the the Z-71 shock but they were the same length as the blue ones I took out. Since my torsion bars are cranked I looks like I have a very little amount of upwards travel available.
Would putting in 3 inch longer shocks mess anything up?
Does anything need to be modified like brakelines, bumpstop, etc....??
Thanks
Old Feb 12, 2007 | 03:29 PM
  #23
04BlackGmc's Avatar
10 Second Club
nothing is modded i have skyjacker N8003
Old Feb 16, 2007 | 09:21 PM
  #24
TX Tahoe Z71's Avatar
I cranked my torsion bars and raised the front about 1". I had it aligned to the tune of $65 and the print out said I was .02 degrees out of alignment. The tech asked why I brought my truck in for alignment. At least it started out as a free mod.
I'm not saying yours won't need it, but mine sure didn't; although if you are putting on new tires, it's always a good thing.
Old Feb 16, 2007 | 09:53 PM
  #25
magoo's Avatar
After cranking, I drove mine about 200 miles. I got a total of 2.5" out of cranking. I will definitely need an alignment. The steering wheel is even off now. After the new bumber and alignement, we will see just how bad it is.
Old Feb 17, 2007 | 06:34 AM
  #26
beastmode's Avatar
Import Moderator
Git R Done
Old Feb 18, 2007 | 08:17 PM
  #27
01midnightss's Avatar
Did you get 2.5" out of your stock TB's? And also how does it drive after cranking 2.5"? This is what I am looking at doing with my truck, but heard I could only get about an 1".
Old Feb 19, 2007 | 03:25 PM
  #28
beastmode's Avatar
Import Moderator
2.5" is alot, his bolts might not have been very tight from the factory, some trucks have the bolts tighter then others
Old Feb 19, 2007 | 06:28 PM
  #29
Bo Duke01's Avatar
where can you get new torsion bars at if you crank them and the front end still sags? Will new t bars even help?
Old Feb 20, 2007 | 05:17 AM
  #30
beastmode's Avatar
Import Moderator
you can just go to a local junk yard and get them im sure for ones off of a truck wit like 10k miles on it... or you can pay out the *** and order em at your local 4x4 shop
