any lifted 2wds?
#22
Originally Posted by gao8302
WHy not have a lifted truck and a lowered truck? One for offroad and one for street/strip.
#24
Import Moderator
well see thats the thing, the blue trucks going cause i need money for a house so it wont be around to much longer... like i said the lift will go on if i get bored of it being lowered so who knows i might nto even put it on
#25
I put a Fabtech 7.5" lift on my '95 Silverado almost two years ago. It holds 35x12.50's just fine. I had never installed a lift before and everything went on pretty smoothly...aside from stuffing the springs in.
#26
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Zach
#28
beastmode, if you want 285's, you'll need the Rough Country 3" lift spindles and the Daystar 2" coil spacers. I have the 2" spacers and have more than enough room for my 265's; I bet I could fit 285's, but they would scrub when I'm turning and hit a bump. As far as the rear, either a 2" or 3" lift block kit will be plenty. This will have you sitting as high as a z71 that has cranked torsion bars. FYI, the z71's come factory with 2" blocks in the rear. As far as your shocks go, you should be okay in the front; I don't know about the rear.
#30
Originally Posted by Chevy Cowboy
How do you like the lift? Is there enough ground clearace now for what you do? How much offroading and what type of offroading do you do? Do you regret not having a 4wd ? Does the lift only fit the extended cab model? I got alot of questions because I want a 4wd but cant really afford it right now so im thinking about getting the same lift for my 2wd reg cab diesel, Thanks
Zach
Zach
