TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
35's???
Old Mar 20, 2012 | 10:46 AM
Brandon5.3's Avatar
Registered User
Default 35's???
Ok i tried to search for this and some of the stuff i found said it would work and some said it would not , I'm new to the lifted scene come from bagged and body dropped trucks, but what i need to know is I picked up a 2003 GMC 1500 4x4 , added 2 inch add a leafs to the rear and cranked the torsion bars up, if i do a 3 inch body lift would 35x1250's fit? or would i need to do anything else? any help in appreciated Thanks
Old Mar 20, 2012 | 10:49 AM
Atomic's Avatar
I have a gauge for that
It will fit with stock wheels, but not if you go crazy offroad. If you are just doing it for the look you will be fine.
Old Mar 20, 2012 | 03:58 PM
bigcountry119's Avatar
Old Mar 20, 2012 | 08:40 PM
Brandon5.3's Avatar
Registered User
Thanks alot
Old Mar 20, 2012 | 09:01 PM
GREENSIERRA's Avatar
I would only lift the rear 1 inch and crank the front to level, with a 3 body lift you will not have any problems fitting 35s
Old Mar 21, 2012 | 09:09 PM
getchusum99's Avatar
like said before, with stock rims, youll be fine. with a aftermarket rim with a nice offset, you will rub, no doubt
