TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
15'' or 16''
Old Aug 17, 2007 | 08:52 AM
roy_b's Avatar
Default 15'' or 16''
First off, I have an 07 NBS, would a 15'' rim even fit?
I have a suspensionmax leveling kit on and Im lookin to run 33 x 12.50 BFG Mud Terrain. I cant decide if I should go with the 15'' or 16" wheel.
Old Aug 17, 2007 | 09:05 AM
beastmode's Avatar
Import Moderator
nope 15s wont fit cause of the brake setup unless you grind your calipers.
what wheels are on your truck now 17s?
Old Aug 17, 2007 | 10:21 AM
MonsterZ28's Avatar
Give me til monday and i'll post my setup, 17x9 w/ 33x12.50
Old Aug 17, 2007 | 04:34 PM
beastmode's Avatar
Import Moderator
i think he was worried about cost for the most part, i think 15s are significantly cheaper than 17s
Old Aug 17, 2007 | 07:22 PM
roy_b's Avatar
I got the 17's on there now, but the tires waitin for me in the garage at home were on a 15 inch rim before, so they have to go on a 15 right. If not I would probably get 16's.
Why dont more people run 15, wouldn't that be better for offroading - more rubber. Wait a minute, that was answered before when I was told they wont fit with the brakes - got it.
What do ya think, is it hard or bad to shave em down?
Old Aug 17, 2007 | 08:13 PM
nightrunner's Avatar
Mr. Obvious
im pretty sure you need 17s to clear the front rotors. i personally havent heard of anyone ever making a different size tire fit on a different sized rim.
Old Aug 17, 2007 | 08:19 PM
truckmann's Avatar
Tires are made for a specific size "period" They can not be made to fit on any other size than the one they where made for. You can't even fit a 16" tire on a 16.5" rim, people have tried for lack of paying attention and it ruins the tire. As far as what can fit on a NBS I have know idea what will fit over the brakes. Really depends on the size of the rotors.
Old Aug 17, 2007 | 09:51 PM
mwalls54's Avatar
Need More N2O Mod
i would not grind anything down on the brakes so you can save a few dollars on tires. the 07s come with 17s for a reason. If gm could get by with putting 15s or 16s on them they would because it would save them money on tires and wheels. if your wanting more rubber then i would suggest putting a larger lift on and then putting some large tires on with 17" rims.
Old Aug 17, 2007 | 10:16 PM
usarmyman's Avatar
My 05 came factory with 17s, I had to grind the calipers on the front to get my 16s to fit. so no 15s. sorry
Old Aug 19, 2007 | 05:16 PM
roy_b's Avatar
Thanks for the info! 17's it is.
I got a pair of 33 x 12.50 BFG Muddin T's for sale on 15's with a 5 lug bolt pattern if anyone is interested.
