TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
Valve spring compressor..... Recommendations
Old Mar 12, 2016 | 07:40 PM
Wolftrk99's Avatar
Originally Posted by TrendSetter
i didnt want to spend the 100 for something i could make myself pretty easily.
If i had the materials i wouldve made something similar... Or tried to.... Good looking tool.... Sure it cost a lot less than $80-169 to make
Old Mar 13, 2016 | 10:39 AM
Atomic's Avatar
I have a gauge for that
I used the flat bar stock one for a while, then I got the comp one which works well. As said just keep it lubed and dont compress the springs more than needed.
Old Mar 13, 2016 | 10:57 AM
Wolftrk99's Avatar
The one i made would work fine if i could find a longer 8x1.25 stud... The one i had was about 1/4-3/8 inch too short.... And a decent nut that didnt have a gap between the end of the nut and the first thread....
Old Mar 13, 2016 | 12:49 PM
Atomic's Avatar
I bet fastenal or mcmaster has something that would work...
Old Mar 13, 2016 | 01:11 PM
Wolftrk99's Avatar
Probably havent even checked there honestly.... Fastenal around here seems to be expensive
Old Mar 13, 2016 | 08:13 PM
X_Racing1's Avatar
this doesnt work? http://www.gearwrench.com/MagentoSha..._FRNT_MAIN.jpg
Old Mar 13, 2016 | 08:25 PM
Wolftrk99's Avatar
Originally Posted by X_Racing1
On factory springs or maybe some beehives, but i couldnt get mine to catch between the coils on my 918s and the center spring on the duals kept popping through the bottom..... Im sure it would work great on my camaro where i could actually get directly over the spring, but my truck im literally hanging off the front end or in my buddy's garage with my feet planted against the wall to balance myself.... Im 5'11" (6' on a good day after a visit to my chiropractors office) and my core support is about 4'11" (guessitmating) so kind of limits the tools you can effectively use and there was no way that style compressor wouldve worked on the rear most cylinders anyway, had ac lines in way of 8 and brake booster on 7..... I plan on taking a night or two this and messing with the truck, possibly swap my trans and converter in and start on my header install, and hopefully get the springs sorted out....
Old Apr 11, 2016 | 11:56 PM
formula53's Avatar
http://m.ebay.com/itm/SILVERADO-SIERRA-TRAILBLAZER-SS-4-8-5-3-6-0-6-2-L92-VALVE-SPRING-COMPRESSOR-TOOL-/331742201902?nav=SEARCH
Old Apr 12, 2016 | 07:44 AM
Wolftrk99's Avatar
Thats essentially the tool i made, just dont have a long enough stud...
Old Apr 12, 2016 | 01:38 PM
X_Racing1's Avatar
weld a couple pieces of steal under the part that touches the spring to push it down more
