TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
LS Lifter Holding Tool
Old Feb 8, 2017 | 03:54 PM
Default LS Lifter Holding Tool
So what I'm looking for is if someone makes this lifter holding tool anymore? I know ThunderRacing use to have a nice one but they are not around anymore...I know everyone uses wooden dowels, magnets, and so forth...I'm looking for ones like ThunderRacing had, I do enough cam swaps that I want something dependable. TIA
Old Feb 8, 2017 | 04:41 PM
TXsilverado's Avatar
I bet if you call Geoff at EPS, he may have exactly what you're looking for. He was the co-founder of TR, and for all we know he may have been the designer of that tool.
Old Feb 8, 2017 | 08:07 PM
Thank you Stew! I didn't even think of Geoff, I used to use him for all my cams until he got super busy back in the day. Then I moved over to Cam Motion. I will give him a holler tomorrow. Appreciate it bud!
Old Feb 9, 2017 | 06:49 AM
madmann26's Avatar
22in wooden dowel rods. 5/16 size.
Old Feb 9, 2017 | 01:32 PM
Thank you for the help! I do not want to use dowels as stated earlier, I know they can be used and the sizes, just prefer the metal fabbed ones. But I appreciate it!
Old Feb 9, 2017 | 01:34 PM
Talked with Geoff and they do not have those tools anymore...He said a local machine shop made them to their spec's, but they are not in the automotive business anymore...Any other ideas?
Old Feb 9, 2017 | 01:57 PM
make your own. why are you so against the wooden dowel rods? I would think the softer wood would be easier on the block/lifters. personally, I've never used any tools to keep lifters up...spin the cam over and let the lifters catch in the trays and slide the cam out never had a problem.
Old Feb 9, 2017 | 04:03 PM
07Softail's Avatar
Kinda what I was thinking
RT
Old Feb 9, 2017 | 04:11 PM
slvrram's Avatar
Any hardware store will have 5/16" mild steel dowel stock. I purchased 2 36" sections from Home Depot and cut them down just shy of 22". Beveled the edges and welded little stopper plates to them from scrap I had laying around the shop. Lubed them up and worked like a charm. Used them 5 times since without issue. Cost maybe $10 bucks and 20 minutes of my time.
As for using the dowels... the second I decided not to, I'd drop a lifter. Cheap insurance and my time is worth much more than the cost of the dowels.
Old Feb 10, 2017 | 06:29 PM
07Softail's Avatar
Hell...steel fuel line will work for that matter!
RT
