TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
Craftsman variable speed bench grinder won't adjust speed
Old Jan 3, 2014 | 09:23 AM
Atomic's Avatar
I have a gauge for that
Default Craftsman variable speed bench grinder won't adjust speed
I was given this grinder a couple christmases ago, havent really ever used it until recently. Craftsman Variable Speed 8 Bench Grinder: Power Up With DealsSears
The variable speed **** doesnt do anything, the the unit appears to run at full speed all the time. It worked the first couple of times I used the unit but hasnt since. Thing maybe has 20 minutes of run time on it.
I took the **** off the shaft and turned the shaft by hand to make sure the **** wasnt just slipping on the shaft and it still feels normal so I am out of ideas short of taking it apart and tinkering with it.
Old Jan 3, 2014 | 09:47 AM
skeet's Avatar
VFD is probably bad or the controller in the motor
Old Jan 5, 2014 | 01:10 PM
silver-mod-o's Avatar
Hunt&Fisherator
I'm sure it's just a potentiometer that controls the speed... Pick one up from radio shack and wire it in and see!!!
Old Jan 6, 2014 | 08:38 AM
Atomic's Avatar
I pulled it apart and tested the resistance of the leads of the ****, 10.2kohms at low and 9.8 at high....that doesnt seem quite right.
Old Jan 7, 2014 | 06:28 PM
Hunt&Fisherator
No it doesn't, seems like there should be more of a range than that.
Old Jan 7, 2014 | 07:16 PM
TIM Z's Avatar
11 sec. Truck Mod
Your thread title= oxymoron.
Similar story , I got a nice ( I thought) craftsman timing light for Christmas 3 years ago , needed it this past summer , it didn't work , tried it on another vehicle , no dice . Wayyy too late to take it back . FML
Old Jan 7, 2014 | 07:17 PM
TXsilverado's Avatar
it's a craftman. take it to sears and get a new one.
Old Jan 7, 2014 | 09:46 PM
AJII's Avatar
thats only for handtools. most power tools have a 1 year warranty and you need a receipt.
Old Jan 7, 2014 | 10:16 PM
throw a mini **** fit and sears will cave every time.
Old Jan 11, 2014 | 09:08 PM
Rudy91040's Avatar
Buy new one, take old one back and say it doesn't work. You get a new one and no problems.
