someone keyed/egged my truck
#41
well i kinda have a suspision on who did it, being i've asked a couple ppl who was at my buddys house and soem ****** that i had problems with in the past was there , so im more than sure that it was him ... and he drives a BLACK 08 crew cab 3/4ton , , i have all these evil thoughts going through my head but ... i really dont want to do anything like that ....but i would love to go to his house about 4 am with a sledge hammer and take 1 BIG swing on his drivers door then get the **** out of there ,
or get one of those metal rakes and rub it all over his truck ,
or get some white spray paint and write all over it
but then i will just be passing along the chain of bad luck , well one day it will happen to him and he will know what it feels like ..
#43
Just thought I would elaborate since the poster did not.
#45
well like i said i parked my truck at that guy house from about 9 am till about 6:30 pm , and like i said i investigated who was there that day , and that guy that i had beef with about a year ago , he was there , in fact his truck was there when i got back to go pick up mine , but it was dark and i diddnt notice anything so thats why im 98% SURE it was him ...
#47
Ok this is not quite right. You now and have been able to for the last 2 yrs able to carry lethal weapons without a license (CHL) in your vehicle. The reason for this is because Texas law has made the vehicle an official extension of personal property. But there are stipulations. You must be in fear of your life or someone has to practically be carjacking you. You can not pull out a gun and shoot someone for keying your car. If you want to read more its bill hb-1815 Signed into legislation by Gvr Perry 11/23/2007.
Below is a copy of the Texas Castle Doctrine also known as Texas Castle Law or as Texas Castle Bill
______________________________________
AN ACT
relating to the use of force or deadly force in defense of a person.
BE IT ENACTED BY THE LEGISLATURE OF THE STATE OF TEXAS:
SECTION 1. Section 9.01, Penal Code, is amended by adding Subdivisions (4) and (5) to read as follows:
(4) “Habitation” has the meaning assigned by Section 30.01.
(5) “Vehicle” has the meaning assigned by Section 30.01.
SECTION 2. Section 9.31, Penal Code, is amended by amending Subsection (a) and adding Subsections (e) and (f) to read as follows:
(a) Except as provided in Subsection (b), a person is justified in using force against another when and to the degree the actor [he] reasonably believes the force is immediately necessary to protect the actor [himself] against the other’s use or attempted use of unlawful force. The actor’s belief that the force was immediately necessary as described by this subsection is presumed to be reasonable if the actor:
(1) knew or had reason to believe that the person against whom the force was used:
(A) unlawfully and with force entered, or was attempting to enter unlawfully and with force, the actor’s occupied habitation, vehicle, or place of business or employment;
(B) unlawfully and with force removed, or was attempting to remove unlawfully and with force, the actor from the actor’s habitation, vehicle, or place of business or employment; or
(C) was committing or attempting to commit aggravated kidnapping, murder, sexual assault, aggravated sexual assault, robbery, or aggravated robbery;
(2) did not provoke the person against whom the force was used; and
(3) was not otherwise engaged in criminal activity, other than a Class C misdemeanor that is a violation of a law or ordinance regulating traffic at the time the force was used.
(e) A person who has a right to be present at the location where the force is used, who has not provoked the person against whom the force is used, and who is not engaged in criminal activity at the time the force is used is not required to retreat before using force as described by this section.
(f) For purposes of Subsection (a), in determining whether an actor described by Subsection (e) reasonably believed that the use of force was necessary, a finder of fact may not consider whether the actor failed to retreat.
SECTION 3. Section 9.32, Penal Code, is amended to read as follows:
Sec. 9.32. DEADLY FORCE IN DEFENSE OF PERSON. (a) A person is justified in using deadly force against another:
(1) if the actor [he] would be justified in using force against the other under Section 9.31; and
(2) [if a reasonable person in the actor's situation would not have retreated; and
[(3)] when and to the degree the actor [he] reasonably believes the deadly force is immediately necessary:
(A) to protect the actor [himself] against the other’s use or attempted use of unlawful deadly force; or
(B) to prevent the other’s imminent commission of aggravated kidnapping, murder, sexual assault, aggravated sexual assault, robbery, or aggravated robbery.
(b) The actor’s belief under Subsection (a)(2) that the deadly force was immediately necessary as described by that subdivision is presumed to be reasonable if the actor:
(1) knew or had reason to believe that the person against whom the deadly force was used:
(C) was committing or attempting to commit an offense described by Subsection (a)(2)(B);
(3) was not otherwise engaged in criminal activity, other than a Class C misdemeanor that is a violation of a law or ordinance regulating traffic at the time the force was used [requirement imposed by Subsection (a)(2) does not apply to an actor who uses force against a person who is at the time of the use of force committing an offense of unlawful entry in the habitation of the actor].
(c) A person who has a right to be present at the location where the deadly force is used, who has not provoked the person against whom the deadly force is used, and who is not engaged in criminal activity at the time the deadly force is used is not required to retreat before using deadly force as described by this section.
(d) For purposes of Subsection (a)(2), in determining whether an actor described by Subsection (c) reasonably believed that the use of deadly force was necessary, a finder of fact may not consider whether the actor failed to retreat.
SECTION 4. Section 83.001, Civil Practice and Remedies Code, is amended to read as follows:
Sec. 83.001. CIVIL IMMUNITY [AFFIRMATIVE DEFENSE]. A [It is an affirmative defense to a civil action for damages for personal injury or death that the] defendant who uses force or[, at the time the cause of action arose, was justified in using] deadly force that is justified under Chapter 9 [Section 9.32], Penal Code, is immune from civil liability for personal injury or death that results from the defendant’s [against a person who at the time of the] use of force or deadly force, as applicable [was committing an offense of unlawful entry in the habitation of the defendant].
SECTION 5. (a) Sections 9.31 and 9.32, Penal Code, as amended by this Act, apply only to an offense committed on or after the effective date of this Act. An offense committed before the effective date of this Act is covered by the law in effect when the offense was committed, and the former law is continued in effect for this purpose. For the purposes of this subsection, an offense is committed before the effective date of this Act if any element of the offense occurs before the effective date.
(b) Section 83.001, Civil Practice and Remedies Code, as amended by this Act, applies only to a cause of action that accrues on or after the effective date of this Act. An action that accrued before the effective date of this Act is governed by the law in effect at the time the action accrued, and that law is continued in effect for that purpose.
SECTION 6. This Act takes effect September 1, 2007.
Suburban2500
Jul 19, 2015 04:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Nimoryan
Jul 5, 2015 03:50 PM
