Ennis Test-n-Tune, Feb. 28th WHO's goin?
#61
Resident Retard
True, lets review the contestants:
Me - my truck is just plain retarded....
Scott - His truck is held together with duct tape and zip ties
Brendan - truck has a mind of its own when it comes to his nitrous....
Eric - last time out hitting the rev limiter or short shifting....
J/k guys, should be a fun day, but my money is Eric winning, then scott, then me, and I don't think brendan will even make it past Tech
Sounds like a plan
Sounds like a plan
#62
Haha, IDK about any bets with anyone else. You guys have the same mods as me + being single cabs = I'll be lucky to keep up on the big side of the track. We'll see though.
Any my trucks been running weird lately.
Sometimes it'll run real strong, then others it will fall flat on its face. I really need to buy EFILive so I can log this thing and see whats going on. To me it feels like the engine completely looses compression, but I know its not because it still pulls decent below 4k rpms and it goes away and runs much better later on or next day.
Me and brendan checked the fuel pressure with a gauge and its between 48-60 psi depending on engine load. But it could be an on and off problem. UGH!
#63
Resident Retard
#64
Hmmm your fuel pressure should not dip that low IMO... Your on and off power problem might be fuel related or it might be pulling spark cause of IAT(if hot it pulls alot of timing), ECT (your efan switch is not the best at keeping a consistant temp), your fueling may be affect because of the same reasons (richening up or leaning out) all that is in the tune.. The fuel pressure thing is mechanical...
Also, it was pretty cool the night we tested it (50s or so). I also rewired my E-fans and they blow alot harder now, so it should be keeping my temps pretty low now and moves plenty of air through the engine bay. And I believe I fixed my exhaust leaks now, but my valvetrain is still so noisey that it sounds like ****. I think I need to move up to 10w30 oil to keep those lifters from being so noisey
#65
Resident Retard
It primed to like 55psi key to run, truck off, then started it was around 50-52 psi, then at WOT it went to 60 psi, and letting off and coasting it went to like 48-50ish again. I didn't seem to dip down any while going WOT at 6.0
#67
Sounds like a plan
Sounds like a plan
#70
Resident Retard
Air density is affected by the air pressure, temperature and humidity. The density of the air is reduced by decreased air pressure, increased temperatures and increased moisture. A reduction in air density reduces the engine horsepower, reduces aerodynamic lift and reduces aerodynamic drag.
