DFW track day Sept 30th Crandel raceway
#71
Was that before or after we wideband tuned it? Cause if it was before that grams/cyl is not accurate. A grams cyl that high indicatez it was pig rich. I have some of the wideband logs we dis along time ago. I will see if i can dig them up for a good comparison since both were heads/cam 6.0s
#72
Resident Retard
Ya i see that now... Check out the difference between dyncylair_dma and cylair_dma. See the difference between the two.. That means that either the VE or MAF was off some. Looking at the Wideband AFR readings it looks like the MAF was off some... Meaning you had a little be left in it... Also i have found that when i added heads it really like a leaner mixture... I wish we would have had a couple more chances to mess with that truck before you sold it.
#73
#78
