Stripped rocker bolt - how to fix
Here's a helicoil kit that I used. The rockers and exhaust are the same size, M8 1.25.
Heli-Coil - Metric Thread Repair Kit Part # 5546-8
LINK TO KIT Heli-Coil 5546-8 - Metric Thread Repair Kit | O'Reilly Auto Parts
I tested this out on an old 317 head that I had before working on the PRC 2.5 head. If I ended up drilling too far or breaking off a bit or tap there were no worries.
The O'Reilly's kit and part number are above.
Here's the bit that used since one was not provided in the kit. 21/64 bit
The right side was not drilled far enough. I went about 1/2 inch down, and this left a few threads of the helicoil hanging out. On the left side, I bottomed out the drill bit in the the original hole. I sunk the helicoil about 1-2 threads down from the surface.
The red dye is from me doing a dye pen test to check for cracks. I can only assume that the rocker bolts were rattled on with an impact or just flat out over torqued.
Drilled, and retapped
showing the tab at the bottom
here's the tang removed. I blew it out with a rag and brake cleaner with a magnet to capture it.
