TECHNICAL WRITE-UPS A place for great instructional threads by members and moderators.
Ls7 Throttle Body
Old Mar 23, 2014 | 03:52 PM
a.vinson's Avatar
Default Ls7 Throttle Body
Anyone with 04 Silverado with the 102 fast intake ever use Ls7 Throttle body?
Figured it would match right up with a 8 pin to 6 pin adapter. HELP ME OUT.
Old Mar 23, 2014 | 03:59 PM
oakley6575's Avatar
I'm running an ls7 tb on my 03. I used a torque rush adapter and it has worked great.
Old Mar 23, 2014 | 04:10 PM
a.vinson's Avatar
Awesome good to here. Thanks, wanted to go with the 102 throttle body, but im not forking $700 for
Old Mar 23, 2014 | 04:14 PM
oakley6575's Avatar
Just to clarify, I have the silver blade 90mm tb. I believe it came on the early ls7's and Ls2's. I bought it on eBay for $250 I think.
Old Mar 23, 2014 | 04:18 PM
a.vinson's Avatar
O, the one i bought has the gold blade got it on ebay for one $150. Is there much of a difference?
Old Mar 23, 2014 | 04:28 PM
03sierraslt's Avatar
Silver is LS2
Gold is LS3
If you are NA then either will be fine, the blade opens opposite direction on the LS2 which is irrelevant for the most part. The LS2 has a stronger servo motor which is why it is the preferred one when you are FI.
Old Mar 23, 2014 | 04:40 PM
oakley6575's Avatar
Silver is LS2 Gold is LS3 If you are NA then either will be fine, the blade opens opposite direction on the LS2 which is irrelevant for the most part. The LS2 has a stronger servo motor which is why it is the preferred one when you are FI.
Old Mar 23, 2014 | 05:23 PM
a.vinson's Avatar
Thanks guys. Oakley I've been looking at those torque thrust adapters how much wiring is involved if any?
Old Mar 23, 2014 | 05:26 PM
Just plug it in, I have one also.
oakley6575's Avatar
None. It is plug and play. You have to cut one wire in the torque thrust loom depending in what model throttle body you have.
