TECHNICAL WRITE-UPS A place for great instructional threads by members and moderators.
Installing 06 Chevy E-fans on a 01 Chevy
Old May 26, 2022 | 02:52 AM
  #151
Dmejia102's Avatar
Were you able to figure this part out? The green and blue wires from harness?
Old May 26, 2022 | 11:04 AM
  #152
RDF1's Avatar
DuNnO
5 Year Member
Old May 26, 2022 | 11:05 AM
  #153
RDF1's Avatar
DuNnO
5 Year Member
99-02 pcm is C1=blue and C2=red
So "Fan 1" is Red 42 and High is Blue 33
Here is a write up showing where all the wires go. Looks like it just needs the PCM color connectors in there and it would be good.
https://www.performancetrucks.net/fo...-101-a-494123/
Old May 26, 2022 | 07:20 PM
  #154
Dmejia102's Avatar
Okay, so i was following the instructions of a post from ScottyBoy, he says to put the green wire on PCM Blue 42 pin and Blue wire will need a Relay that we need to be splice under the fuse box to be trigger, Is this not accurate?
Old May 26, 2022 | 10:39 PM
  #155
RDF1's Avatar
DuNnO
5 Year Member
Depends on how your harness is setup.
Some are setup for the AC Compressor 12v+ trigger wire.
The PCM is a ground trigger output.
Factory 2005+ harness has both trigger wires going to pcm that need a ground trigger. Aftermarket harness could be wired up several different ways.
Old May 27, 2022 | 12:26 AM
  #156
Dmejia102's Avatar
Okay, Thanks for your help.
Old Jun 4, 2023 | 12:06 PM
  #157
adriver's Avatar
FYI - The oil cooler line thread size. #1 here, found some conflicting information, and never the right size.
#1 is M20 X 1.5. (Dorman M20 x 1.5, oil drain plug #69015)
Old Jun 30, 2023 | 11:17 PM
  #158
Neekwill's Avatar
Registered User
Default Efans
So I have a 2003 silverado 1500hd. I currently did the electric fan swap. I took the fans and the harness from an 2005. Once installed I got a buddy to tune, and enable fans.
Wiring - small green wire pinned in blue 42. Small blue wire pinned in 33 green. Power and ground connected......
Well what I'm recognizing is that only the passenger side come on high once a/c pressure build up and in the middle of me driving. It's weird because I let the truck sit and run and idle to see when fans cut on at what temp. Temp gets to 200-210 and fan never cuts on. Only when I'm driving for a while and I come to I stop I hear the fan. So I don't know when they actually come on.
Does both fans suppose to cut on at low speeds??? Are both fans suppose to cut on at high speeds ???
When I ground the green from the fuse box both fans come on low. When I ground the blue one passenger side comes on high
Old Jun 30, 2023 | 11:51 PM
  #159
RDF1's Avatar
DuNnO
5 Year Member
Depends on how he setup the tune.
Get him to email you the tune and post it here so we can see what it wanting to do.
If nobody has messed with the wiring off the 05 harness it will be the Dark Green wire that goes to Blue 42 is Low Speed so both fans are on low.
Dark Blue goes to Green 33 which is high speed. If High is triggered then only Passenger fan will be on high.
IF Low and High are triggered then both fans will be on high.
Old Sep 6, 2023 | 11:47 AM
  #160
Nor209610's Avatar
Registered User
Originally Posted by ScottyBoy
Green turns both fans on low. Blue turns only the right fan on high. If green and blue are both grounded at the same time, then both fans turn on high.
i did everything how it says right here low speed both fans work as soon as i turn on my ac only one fan goes to hi speed, the other one turns off, whenever i turn back off the ac both fans turn on on low speed, would it be safe to turn on the ac with just one fan on high speed or would the truck overheat? Or what can I do so both fan turn on hi speed at the same time
im using a 2006 Silverado oem harness on a 2001 Silverado
