Originally Posted by wizzle335
(Post 4701590)
Not an option on trucks without a cassette player?
beingblueeyes = :hail::hail::hail::hail:
I love tech mods like this! Too bad I already have my aftermarket sitting in the closet. :cry: Great write up!!!!! :cheers: |
Nice write up! I had a 6 disc from a buddy's SS that I got for free that I was going to do this mod on. Ended up getting a after market head unit instead.
Originally Posted by beingblueeyes
(Post 4701712)
you would need a tape player or cd player for this, im 99% sure it cant be done with just a fm radio
I have the cd player, but no tape player in my 04 RC. Would the wire up be the same? I'll check to see if the chip is the same. |
(Post 4703044)
Awesome write up man, I want to give this a shot on my 6 disc changer
I have one questions though, if I have the CD/Aux button on my head unit wouldn’t I just be able to use the AUX_L and AUX_R for inputs instead of tying into the CD player and having to put a blank CD into the changer? Any thoughts would be helpful! |
So, I pulled my stereo out and it doesn’t look like the AUX pins go any ware so I guess that’s out but now I am wondering why I have TAPE pins if I don’t have a tape deck?
And yes I do have the same chip SAA7706H. So with the 6 disc changer (and the input soldered on to the CD_L & CD_R) could I just leave one blank disc in the changer and when I want to use the input just change to the CD and turn on the input device? And one more, I do not see a “ground pad” where would a good point be to attach the ground? Pic of my board: http://i329.photobucket.com/albums/l...g/P2210112.jpg |
7 Attachment(s)
This is a copy from a write-up I did on GMFS.
Bump. Finally did this on my 03 Yukon Denali. I have the RSE, XM, Bose and 6 disc changer and everything works as it should. As a side note, doing this will over-ride the XM, CD changer, and rear seat entertainment imputs. Therefore you'll have to unplug from the aux jack to use any of the original sources. 1st: Parts and tools Attachment 143637 Attachment 143638 Cable I made with 18ga. wire Attachment 143639 Center console drilled with jack installed. A 1/4" bit should be fine for the hole, but I had a index that goes to the 32nd so I used two steps down from 1/4" and it's preety damned snug. Attachment 143640 Spliced into the harness behind the dash. This seemed easier than opening the radio to me. The wires will be in a bundle wrapped with tape and shielding. DO NOT get the other green wire that isn't wrapped up with the shielding. Pin 1: To black/white wire Pin 2: To Radio side of brown/white wire Pin 3: To XM side of brown/white wire Pin 4: To XM side of green/white wire Pin 5: To Radio side of green/white wire Attachment 143641 yes, I heat shrinked everything and taped the bundle back up when I was done. Attachment 143642 It works! still use the cigarette lighter, it's one of 4, but I can leave the ipod on a charger in the console this way. Attachment 143643 http://www.youtube.com/watch?v=2pxUZ...3&feature=plcp sorry for the picture quality, I broke my samsung so I had to use an old shitty panasonic. Also, shot the video with my ipod nano 5. |
I did this on my 05 chevy silvy with 6 disc, res, xm. I only have one problem when i connect my phone to the jack it doesnt cut out my xm sound completely. I can still hear it very fainlty. Any ideas on why it would only partially cutout my xm.
If you did it externally as I did, you may have melted the jack when soldering the wires on and two of the pins are making contact. Mine I could hear faintly but only if my aux source was turned off (the ipod) and the volume was cranked past halfway, but I chalked that up to a lack of shielding in my homebuilt cable. People have used cat5e cable with good luck as it has a capacitance twist as shielding between the individual wires.
I'd also check that all your splices are well insulated (heatshrink or good electrical tape) as you could have a stray strand crossing over that was overlooked. |
