Corvette Z06 Wheels on a C1500 454SS
To install the fifth generation (C5) Z06 wheels on your Chevy C1500 you simply need some spacer adapters to counter the wheel's offset and get from the factory truck 5 x 5" to 5 x 4 3/4" bolt pattern.
Here's the spec. I wrote for mine and provided to parts supplier.
Installing 2001 Corvette Z06 Wheels on a 1991 Chevy C1500 SS454:
• Spacer Depth = 1 1/4" (31.75)
• Vehicle Hub Flange = M14-1.5 x 5 x 5 (127)
• Wheel = M12-1.5 x 5 x 4 3/4 (120.7)
• Lug = Truck has a M14-1.5 lug size and the wheels have a M12-1.5 lug size
I actually found mine on eBay for around $125 for the set of four.
Note, however, that if you slam your truck as low as I did then the front end takes some lower A-Arm work to clear the inside lip on the wheel. You’ll either have to go with a narrower wheel, different offset (can be counted somewhat with the adapter thickness) or modifications to the lower A-Arm (trimming or replacing with tubular.
1) All C5 Z06 wheels were the sizes mentioned above.
2) Chrome was not a factory option on the Z06 wheels. Any chrome plating of factory wheels was done at great cost after delivery.
You had aftermarket wheels.
