TECHNICAL WRITE-UPS A place for great instructional threads by members and moderators.
Cleaning up under the hood
Old May 7, 2012 | 08:49 PM
squrrielsz71's Avatar
Default Cleaning up under the hood
well this is the first time i've posted anything on here so here goes. this may sound a bit crazy or even a waste of time but its a good excuse to go out in the shop. i would like to clean up the engine bay on my 03' sierra. ive read a few posts on swapping the truck intake for a LS1 intake too make it look better but you give up alot of bottom end performance. I've seen a few truck intakes smoothed and painted. makes the intake look alot better. i also want to go with aftermarket fuel rails. the factory rails on my truck now has the fuel pressure regulator incorperated in the drivers side fuel rail with a vaccum line going into it. would i be able to run a returnless system? or buy an aftermarket regulator too take care of this? i also have another intake off an 04' 5.3L truck that is returnless and does not have a vacumm line going into the regulator. can i just swap intakes with no problems?
Old Dec 14, 2014 | 11:36 AM
Show-n-go5.3's Avatar
yes u can use an after market regulator that has a return. If u get after market fuel rails u will have to make ur own mounts probably. Any Ls intake will bolt up. the new style truck intakes have better flow than the old w/bigger throttle body. If u get an intake that dont have EGR u will have to remove it and block it off in ur manifold. U will also have a code if u dont delete it. I ported and shaved my factory 03 intake. since that pic i shaved the original fual rail mounts to. Its a lot of work. Here is a quick peek at one i was going to use but it wont hold 20psi of boost lol.
[IMG][/IMG]
Old Dec 17, 2014 | 01:24 PM
Richb1422's Avatar
[IMG][/IMG]
wow that looks a lot better then factory
Old Jan 12, 2015 | 03:58 PM
Rootbeer02's Avatar
Covers look good
Old Jan 21, 2015 | 11:42 AM
The_W's Avatar
Nice, looks good. I have been debating the LS intake fo rsome time to give it a good look. But hard to give up the bottom end performance as you well said. Keep pics coming.
Old Jul 5, 2015 | 12:25 PM
slick_sierra's Avatar
Gotta get someone to post up a wire tick how to!
Old Jul 6, 2015 | 04:34 AM
Not a wire tuck but a little cleaner than GM intended.
Old Jul 6, 2015 | 09:35 AM
BlackGMC's Avatar
Resident Retard
who makes those coil overs?
Old Jul 6, 2015 | 10:36 AM
I made them.
Old Jul 6, 2015 | 12:18 PM
That looks clean as hell
