where to tap
just wondering where some of you guys tapped in your 12+v gage power( a positive that turns on with you instrument cluster)
when i went and did the test light routine i found that on mine its a negative switch. meaning i hooked up my test light to the battery 12v+ and it gave me the signal i was looking for, but when i hooked it up to a negative it wouldnt work.Sorry kind of noob question just a bit stumped
cruise control is allways my favorite for 12+ switched power, it can be found in the fuse box on the side of the dash... my reasoning is that for stereo related items it gives no feedback and if I ever blow the circuit (never have) it's only cruise control, I can still make it home.
His truck might not have a Acc. catch it at the ignition harness.
Get a 7mm socket take off plastic under dash.
Then get a 10mm socket with an extension take off the metal knee protector under the steering column.
Tap into PINK for Ing. or ORANGE for true ACC. wire using a fusable link.
Good luck
Good luck
Good luck
Good luck
lxcoupe
Sep 25, 2015 12:36 PM
GM1697
Sep 9, 2015 01:52 PM
