Tripple gauge pillar
Old Jan 4, 2006 | 08:55 PM
TIM Z's Avatar
11 sec. Truck Mod
i got one interceptor scan gauge, its awesome and does almost every function you can think off, lots of good info, and then a boost gauge in my dual pod mount. this gauge also monitors trans temps and IATs.
Old Jan 5, 2006 | 11:00 AM
natural1's Avatar
I, myself, would do the engine oil temp, fuel pressure and egt. Or, swap the oil temp for a boost/vac if you plan to get a blower some time. I don't see spending $50 on non-wideband a/f lightshows. Get gauges that tell you something.
Old Jan 5, 2006 | 11:11 AM
natural1's Avatar
I just looked this up. These are great...I want one. (an interceptor)
http://www.aeroforcetech.com/
Old Jan 5, 2006 | 11:54 AM
slowprocess's Avatar
A narrow band will tell you "something". I mainly use my narrow band for track/nitrous purposes. After I first installed the gauge, of course it does the whole light show riding around....when I ran it at the track, it would stay right where it was supposed to be. When I first started spraying the truck, I noticed it was now moving over to the rich side every pass. I played it off as the gauge was wrong because everybody on here talks about how bad they suck, don't tell you anything, etc. Finally we got to screwing around with the nitrous kit one day and checked the jets. Sure enough there was too big of a fuel jet being used. Replaced the jet and everything was where it was supposed to be again going down the track and for some reason the truck woke up alot more.
My $50 was well spent in my opinion. I have no tuning software, so a wideband would just be several hundred dollars worth of useless numbers for me to look at and wish I could do something about. I do have ls1-m for logging passes as well.
I think my several hundred would be more benefitial being spent somewhere else....at least until I had the software to do something about it.
Old Jan 5, 2006 | 12:32 PM
natural1's Avatar
I hear ya, I just usually tune with a wb or egt.
Not bashing.
Old Jan 6, 2006 | 05:58 PM
sikchevy's Avatar
im gonna end up doing a narrow band for sure for right now, and then later on when i get software i will get a wide band. that interceptor gauge is pretty bad *** as well. thanks for all the good info.
Old Jan 8, 2006 | 02:49 PM
TIM Z's Avatar
11 sec. Truck Mod
here is a pic of my interceptor mounted with my boost gauge, just a pic to look at, -- tim
Old Jan 8, 2006 | 02:51 PM
TIM Z's Avatar
11 sec. Truck Mod
and one more.
Old Jan 12, 2006 | 12:39 AM
smooth_addictions's Avatar
summit wharehouse. 2 days and counting. cant wait.software: soon to come!
Old Jan 12, 2006 | 04:07 AM
ap2002's Avatar
get you one that tells you the outside temp!!!
j/k....
I would have suggested the tranny temp meter but since you already have it on you gauge cluster, nevermind...
I know they sell some 1k-8krpm meters that are that size too??
