Just bought a gauge cluster with trans temp in it and I want to try to get it to work with the NV4500. The NV4500 does not come with a trans temp sensor of any kind but it should be fairly easy to add since the NV4500 has a PTO port on each side and there are PTO coolers available that space the cover out a few inches and one even comes tapped with a sight glass. My plan was to buy a PTO cooler, weld a bung to the cover with the correct threads for a sensor and plug it in like normal, the problem is I'm not sure what sensors will work. I see a factory 2500, 6.0 trans temp sensor that looks like this first picture. Clearly there are no direct threads and instead, the sensor plugs in and is sealed with an O-ring and held in place by a mounting bolt. I'm not sure how I would be able to adapt that to fit directly into a PTO cover as shown in the second picture.
Does anyone know of another sensor that could be plug and play? Or is the trans temp gauge simply looking for a 1-5v signal and maybe a universal sensor like this would work?
I found some data on the resistance values and it looks very similar or exactly the same so I think your right an ECT sensor should work. SImply gotta grab the 2 wires from the trans harness and make a pigtail. I'll test everything in a bowl of hot water and verify with an IR gun.
I will just buy a PTO cooler and use the 1/4npt drain plug port or get an adapter to mate up to the ECT. No custom machining is required.
Pretty sure the trans harness is just shoved under the hydro-boost master. I've pumped I've been wanting to do this since I melted the NV3500 in my RCSB, just curious to see temp differences when towing in OD vs 4th.
