Switchback led problem
Old May 4, 2013 | 08:40 AM
Default Switchback led problem
I just started switching all my bulbs to LEDs. All of them work fine except for the switchbacks. I upgraded to the electronic flasher so they blink fine. But the parking lights are not white. Just a few amber ones light up. Does any one have any ideas?
It's a 99 silverado nbs
Old May 5, 2013 | 01:46 AM
05GMC4.8's Avatar
you may have to move the pins on the bulbs them selves to the opposite sides. mine did that and i had to move the pins on a couple. i used the resistors though
Old May 5, 2013 | 02:56 PM
Do these trucks have a ck socket type? That might be the problem. Time to break out the test light
Old May 5, 2013 | 10:16 PM
5speedsilverado's Avatar
i had the same issue, i had to throw a resistor on them and no problems since
Old May 6, 2013 | 03:49 PM
I just noticed if I take out the 194 bulb then the switchbacks work fine. But as soon as I plug it back in it grounds out the white part of the switchback.
Old May 9, 2013 | 04:12 PM
So I just took out the LEDs in the rear blinkers and replaced them with the stockers. Now the switchbacks up front work fine. Do I need resistors for the rear? The rear bulbs are 3157s right?
Old May 9, 2013 | 05:07 PM
05GMC4.8's Avatar
U need a resistor for each switchback bulb
Old May 10, 2013 | 05:43 PM
Do I need the 6 ohm 50 watt resistors? And which wires do I splice them into? Sorry for all the dumb questions. Thank you guys for your help.
Old May 16, 2013 | 06:00 PM
So I got the resistors and wired them in. Problem solved. Thanks for the help.
Old Jun 25, 2013 | 06:37 PM
Rule69's Avatar
What wires did you put the resistors on? Also what size resistors?
