Sub and amp advice
I have an 07 Sierra Denali classic with factory nav and was recently given an alpine mrp-m350 amp and 12" DUAL subs. What is the easiest way to install these myself and which wires do i tap into? Any help would be great!!!
Originally Posted by txredxj
yes you will need a way to get rca outputs. and an acc is what you will need for your remote turn on for the amp. you will also need a good amp kit. 4 gauge or better.
Agree w/ everything but the amp kit. Unless your going to upgrade, 8 ga is good for up to 400 watts.
tag into a couple speaker wires preferably at the factory amp for you LOC to give you RCA preouts like tyler said. your acc wire under the steering column is orange or you can tap into the pink wire which is ignition(both wires are about 12ga. size). and like the guys already said 8ga. will be fine for that amp....
4ga. does not fit into that line of alpine amps, you can make it fit but you have to strip the wire down to 8ga. so just save yourself the trouble and run 8ga. and yes you need to run it at 2ohms bc if you run it at 8 ohms you wont hear very much
A distribution block would work fine. I always recommend going to 4 gauge, because for most people if they upgrade they add a comp. amp, or bigger sub amp, they can still run the 4 gauge with no problems.
