Silverado Gauge Cluster Swap
Old Nov 6, 2012 | 05:01 PM
bluebird71's Avatar
Default Silverado Gauge Cluster Swap
If I wanted to swap in say an Escalade or SSS gauge cluster into my '03 Silverdo, would everything on it just work as normal (namely the trans temp gauge that isn't present on my stock cluster)?
Old Nov 6, 2012 | 09:45 PM
WorkTruc's Avatar
Plug it in and evrything will work including trans temp
Old Nov 6, 2012 | 10:45 PM
2000chevysilverado's Avatar
Yep mine swapped over perfectly on my 2000 took 15 min in the dark
Old Nov 6, 2012 | 11:46 PM
bluebird71's Avatar
Is there a year limit up to that it will work in my '03, as long as its the same body style?
Old Nov 7, 2012 | 12:08 AM
I think 03 to 05 not sure
Old Nov 7, 2012 | 01:29 PM
1FSTMAX's Avatar
03-07c will work on your truck. Some of the 05-07c may give you a battery light, however everything will work like it should.
Ketis
Jul 23, 2015 12:37 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
oharajo
Jul 18, 2015 09:24 PM
chacho44
Jul 16, 2015 09:03 AM
My72olds
Jul 10, 2015 11:26 AM
