running wire?
Old Nov 13, 2011 | 06:13 PM
01silvy's Avatar
Default running wire?
How do you guys run wire from the inside of the cab to the engine compartment and keep it clean looking? I'll be doing this on a 2001 silvy
Thanks, Jonathon
Old Nov 13, 2011 | 06:27 PM
SlickSierra's Avatar
I use the rubber grommet on the firewall under the wiper motor
Old Nov 13, 2011 | 06:32 PM
smokeshow's Avatar
Mod with training wheels
I drilled a hole and put a grommet in it. Looks clean.
Old Nov 13, 2011 | 06:38 PM
Dewey's Avatar
I did the same thing. I drilled a hole through that little indention under the master cylinder, and it came out right near the steering column. I had to run to the back of the cab, and i tucked the wires under the plastic panels, and down the track that's under the sill plates at the bottom of the door.
Old Nov 13, 2011 | 07:04 PM
01silvy's Avatar
Ok, thats looks pretty clean.. where do you get the grommets from?
Old Nov 14, 2011 | 04:25 PM
01silvy's Avatar
Also could you post up a good pic of where this grommet is under the wiper motor? I cant find mine.. i see a grommet beside the brake booster but im not sure if thats it or not..
Thanks guys
Old Nov 19, 2011 | 01:02 PM
budhayes3's Avatar
PT's Slowest Truck
Thanks guys
That's the one...the big grommet that the main harness goes through. I've run a bunch of stuff through there by removing the tape on both sides and using a plastic snake to pull wires through. Then, after I decided that I'd run enough stuff through there, I drilled a hole and used a rubber grommet as the others have mentioned, right beneath the factory grommet.
Old Nov 21, 2011 | 07:57 PM
01silvy's Avatar
Oh ok, i gotcha.. where do yall buy the rubber grommets from?
Thanks for the help
Old Nov 21, 2011 | 08:16 PM
Mangled03gmc's Avatar
Baltimore Whore
I went rite through where the main harness comes through the fire wall by the inner fender well.. It has a grommet already where all them wires come through at.. Just be careful and open it up some with a razor, run your wire with the rest of them
Old Nov 24, 2011 | 11:28 PM
01silvy's Avatar
Ok thanks guys, ill probly work on this the first of next week so ill see how it ends up.. thanks for the help
