PAC interface for bose in an 06 Silverado
Old Sep 22, 2008 | 05:59 PM
BigCountryx's Avatar
Default PAC interface for bose in an 06 Silverado
Looking to install a Pioneer AVH-P4000 in an 06 Silverado. No XM, no OnStar, or steering controls. Will the PAC GM24-OS2 interface be all I need for all chimes and factory functions to work? I'm planning to keep all the factory Bose equipment functional and add a small amp and sub to the system. Should this work out and be a fairly clean sounding system? And do I need any other installation kit for the unit?
Old Sep 23, 2008 | 02:42 PM
53bowtie's Avatar
yeah that should be all you need to interface with the bose. You will need an atenna adapter as well. The unit should come with ears for you to screw it in the dash with the factory screws so no dash kit is required.
Should sound pretty good, as a personal preference when i put aftermarket subs into vehicles with factory subs i usually unplug them so the aftermarket sub is all that is playing the low notes. Good luck with it all.
Old Sep 23, 2008 | 06:23 PM
Thanks, that's what I was looking for. I'm just gonna put a single 8 under the rear seat, not looking to bump the neighbors, just want it better than stock. I'll try it with and without the factory sub and see how it sounds.
Old Sep 23, 2008 | 09:45 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
uh what kind of truck? check metraonline.com & check the harness - into car i think it's actually GMOS-04
Old Sep 25, 2008 | 04:09 AM
06 Silverado SS with bose, but no OnStar. Emailed PAC and they confirmed that PAC GM24-OS2 is what I need. Now looks like the METRA GMOS-04 will do the same thing for a few dollars less. Anyone have an opinion on which is better? PAC or METRA
Old Sep 25, 2008 | 02:19 PM
53bowtie's Avatar
i was gonna say the GMOS-04 wat metra not pac......I say go with the cheapest one since they both do the same thing and are both made by respectable companies.
chopperloco
Jul 10, 2016 10:45 PM
mzoomora
Jan 3, 2016 07:06 AM
thunder550
Oct 8, 2015 04:53 PM
JordanH
Aug 8, 2015 07:59 PM
black6spdz
Jul 16, 2015 01:32 AM
