Need help
Old Mar 29, 2007 | 07:17 PM
Blue5.3's Avatar
Default Need help
I lost power to my right door and keyless entry. I looked at the fuses. I am guessing it would be the right door fuse under the hood? What else could it be. Thanks for any help.
Old Mar 29, 2007 | 07:31 PM
CHEVRACER83's Avatar
Check The Fuse Door On The Side Of The Dash
Old Mar 29, 2007 | 07:45 PM
Grumpy5.3's Avatar
here is a bulletin, you need to go to the deer and get the passenre door module reflashed
Subject: Remote Keyless Entry (RKE) System Inoperative (Reprogram Passenger Door Module) #03-08-52-001C - (03/17/2003)
Models: 2003 Cadillac Escalade, Escalade ESV, Escalade EXT
2003 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003 GMC Sierra, Yukon, Yukon XL
2003 HUMMER H2
From Start of Production (SOP) through December, 2002 for the 2003 Model Year
This bulletin is being revised to provide the latest service information. Please discard Corporate Bulletin Number 03-08-52-001B (Section 08 -- Body and Accessories).
Condition
Some customers may comment on any of the following conditions:
• The RKE key fob does not function.
• The RKE has a very limited range.
• The passenger door will not unlock from the passengers or drivers door switches.
• The passenger door window is inoperative.
Correction
Important: For clarification purposes, the following information is provided. The components involved in this bulletin are known by various names. The Service Information Document ID #849813 refers to the component as the Door Lock and Side Window Switch. General Motors Service Parts refers to the components as SWITCH DR LK & SI WDO. Within this component is a micro processor that is referred to as the Passenger Door Module (PDM). Techline equipment refers to the component as the PDM Passenger Door Module. This bulletin addresses issues with the software of the microprocessor in the Passenger Door Module (PDM).
Perform the following procedure step by step (do not skip a step) to determine the proper course of action.
Important: Verify the software version in your Tech 2. If the software is not 23.001 or newer, your Tech 2 software needs to be updated.
Determine the production date of the vehicle by viewing the certification label on the driver's door.
• If the vehicle's month of production is PRIOR to 01/03, go to Step 2.
• If the vehicle's month of production is 01/03, THIS BULLETIN DOES NOT APPLY. Refer to Customer Satisfaction Program bulletin 03011, published March 2003.
• If the vehicles month of production is 02/03 or newer, this bulletin does not apply. Refer to published Service Information for the symptom experienced by the customer.
Use the Tech 2 to determine the PDM operational software release number.
• With the Tech 2 installed and powered up, verify the software version. If the software is not 23.001 or newer, your Tech 2 software needs to be updated.
• Press Enter.
• Select: Diagnostics.
• Select model year: 2003.
• Select: Light truck.
• Select : Body.
• Select the proper Product line.
• Select the proper HVAC Type.
• Select the proper Radio System type.
• Select: Passenger Door Module.
• Select: Data display.
• Select: Module 1 information.
- If a number is displayed following "Operational S/W Part Number" , continue with the next bullet.
- If an (*) is displayed following "Operational S/W Part Number" , go to Step #3 below.
• If the "Operational S/W Part Number" is 15181562, 15186199 or 15186460, exit out of this bulletin procedure. Refer to Service Information to diagnose the condition reported by the customer (the vehicle has the most current software as of the date of this bulletin).
• Exit to the Main Menu.
• Perform normal SPS reprogramming of the Passenger Door Module.
• Go to Step 4.
If an (*) is displayed following "Operational S/W Part Number" , return to the screen which will allow you to select the Passenger Door Module by pressing Exit (3) times.
• Select: Special Functions.
• Select: Refresh.
• Follow all on-screen instructions.
• When the Tech 2 displays "Refresh Procedure Successful", Exit to the Main Menu.
• Go to Step 4.
Return the vehicle to the customer.
Old Mar 29, 2007 | 07:51 PM
OR INSTAED OF CHECKING FUSES YOU CAN DO IT THE EASY WAY AND DO WHAT GRUMPY SAID
Old Mar 29, 2007 | 08:06 PM
Blue5.3's Avatar
Thanks for the help. I hate going to the dealer
Old Mar 31, 2007 | 02:42 AM
D King's Avatar
THere is one other fuse box under the dash left of the break pedal that also has some controls there, found it when trying to disable my windows after they were tinted.
