keep blowing Relays...............e-fans
what a rush!
I keep blowing relays using my efans, is there something better I can switch too? Kinda sucks when your truck starts overheating because the relay took a **** and the fan didn't come on.
What is a solid state relay? any better?
I had the same problem, started looking for a soft start controller then just gave up and went back to a clutch fan. Are you using 30 or 40 amp relays? I saw in another thread somewhere that when the fans fire up on high they can spike draw up to 70 amps, thats gotta be what is doing the relays in. I believe in stock applications the fans do some kind of soft start.
What harness are you running... if you can get me a pic of the plug... i can see if i can match one.... should be running no lower than a 40 amp relay...
a 70 amp spike wont hurt it, as long as its a spike... no longer than a second
what a rush!
Originally Posted by redwagon
they definately spike higher than 30 or 40. we had to run 60A in my brother's truck.
Originally Posted by moregrip
hmm, never seen one of those....................I wonder if the fact that I'm running a 105 alt has anything to do with it.
Cheapest, and easiest fix is to run 30 Amp relays in parrallel. Then the spikes will not go over max load, and obviously normal running will be way under. That would last forever if good qualitly relays.
Or if you wanted to get really caried away, use a starter solenoid. But that would be overkill I think.
All of this should not be necessary though. No one else is having issues. Maybe just verify with an amp clamp the draw on system, then verify all is hooked up good, verify good grounds and battery connections. Those cause a very high load on wiring and would cause amps to increase.
Good luck man!
