Issues wiring in Reverse Lights
Old 07-08-2018, 01:59 PM
ironcityboom's Avatar
Default Issues wiring in Reverse Lights
I'm finally getting to these reverse Lights but Im not sure if I'm sourcing the correct wire...I've tried to find pictures but it seems most guys talk about a lime green wire for the reverse Lights but all I have is this darker green wire(circled in picture) and isn't doing **** when I put 12v to it. I've checked the bulbs, they're good. Also checked fuses...unless I'm having a brain fart and missing something obvious. I should also note that I no longer have a neutral safety switch anfter swapping to a TH400. Is there possibly another source under the dash that can be tapped?
Old 07-09-2018, 07:40 AM
ILuvJDM's Avatar
Here's the wire I used to switch my headunit to backup camera when my reverse lights come on in an 06/07 truck:
It's the far right BCM plug C5 and it's the light green one next to the gray/black
Old 07-10-2018, 08:31 AM
ILuvJDM's Avatar
Edited my post, that was the steering wheel control wire I called out originally
Old 09-01-2018, 02:45 PM
1redta's Avatar
I put an led under my bumper tied into the reverse wire of my trailer harness. works great and only works when the truck thinks it’s night time
stg313
12-30-2011 04:47 PM
thunder550
10-19-2006 10:08 AM
loco_silverado
02-21-2006 07:07 PM
Quick Reply: Issues wiring in Reverse Lights
