heres my setup..what do u think? (PICS!)
Old Jul 25, 2008 | 08:37 PM
matthimself's Avatar
i have a similar box... but mine doesnt have the amp rack in the middle.... and i need the 1000/1 i only hav the 500/1
Old Jul 26, 2008 | 05:11 PM
xaustin's Avatar
Originally Posted by 53bowtie
Looks good. Seems to me that the boxes are a littl small for a w6 but if it sounds good then thats all that matters.
Not sure how the OP did it but a friend of mine raised his back seat up with a solid piece of metal with 2 holes drilled in it for the studs to raise it up a bit.
nope, the recommended box volume for a sealed w6 is .65 cu ft and its exactly so.
and yup, thats all i used to raise the seat as well..
Old Jul 26, 2008 | 06:57 PM
53bowtie's Avatar
true that. but i would still run it around 1 cu ft IMO......looks dang good though, clean install
Old Jul 27, 2008 | 11:29 AM
xaustin's Avatar
dont want to make them too much oversized or you'll get horrible bass response. really should always go with the recommended specs for sealed boxes.. i polyfilled them but thats as much as i'd do.
but thanks for the compliment
Old Jul 27, 2008 | 05:12 PM
53bowtie's Avatar
yeah, i guess if you are just starting out and want to be on the safe side sticking with the factory specs is the way to go. I have learned through experience that depending on how you like your bass output and sound quality the factory specs are not always the best way to go so i like to experiment with several boxes to see which suits my needs the best. That is what i am in the process of doing right now in my truck.
Old Jul 27, 2008 | 06:24 PM
GMCtrk's Avatar
bigger box = boomier
smaller box = tighter bass
If you have a big and you want to increase the effective volume of the box simply add some polyfill.
Old Jul 27, 2008 | 08:29 PM
venomhp's Avatar
Looks great!
Old Jul 28, 2008 | 12:19 AM
One_Slow4.8's Avatar
poly fill is just cotton right?
Old Jul 28, 2008 | 12:54 AM
07redchevy's Avatar
i had the same set up in a single cab im about to do the same on my 07 same amp and subs
Old Jul 28, 2008 | 01:36 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
nope...polyester fiberfill = polyfil...and it's the stuff that's inside of a pillow...for $2 at wally world (wal mart) go buy a pillow cut the bitch open and test & tune...THERE IS NO FORMULA FOR POLYFIL and everyone has their own ways but i say
2.5 - 3.5 cu.ft. = 1/2 lb polyfil/cu.ft.
3.5 cu.ft. + = no more than 1 lb polyfil/cu. ft.
