HELP! Radio Lights
mine are getting to where they are slow to some on with a delay of some sort
i think they are probably incadescent because the dim with the dimmer on the headlight control panel and LEDs require a completely different type of dimmer with a resistor type of thing and i know for a fact the 99-02 style instrument cluster has incadescent bulbs in it...
They are led's and they can be replaced, but it is diffucult to do if you aren't skilled at soldering. The area to solder is very very small there are some people around that will do it for you and you can even have a different color led's installed, but it will probably be cheaper to just buy a new radio.
I found some picutres somewhere of a truck where the guy had replaced every led in the truck with blue one's. I mean "every" led, steering wheel buttons, window switches, heated seat buttons, radio, ac control, gauge cluster and anywhere else there might be an led. It looked really nice, but I bet it took a long time to do and cost a small fortune.
Originally Posted by nightrunner
remember he has an 02 not an 04 which are completely different lighting systems
Even so the new bulb's are going to need to be solderd in to the pcb of the radio.
dantheman1540
Feb 24, 2016 09:56 PM
drummer0415
11
Oct 24, 2015 08:16 PM
carid
Oct 1, 2015 09:22 AM
I have the same issue! The whole bottom left corner of mine doesn't light up any more.
