Fuel Pressure Guage Reading Low
On the driver's side fuel rail, near the middle of the rail should be a small vacuum hose pushed onto the fuel pressure regulator. Pull off the hose and start the engine, see what your fuel pressure is. You can plug the vacuum hose with a small phillips screwdriver if you want, but you're only gonna start the engine for a few seconds, so it's not important.
UPDATE-At least my truck isn't fucked up.
I bought a cheap little fuel pressure gauge from harbor freight and after a bit of wrestling with it, I got it working. It's reading around 49-50 with the key on and a tiny bit lower with the engine running.
I suppose that means the sender for my gauge is messed up. I'm still at a loss as to why it's reading right, just 10 psi low.
do you guys have the little black box gauges or the newer ones? ive got an extra little black box that i will sell for cheap if that may be the problem. i just gotta make sure they both work the same on my truck first haha
... totally forgot i was searching for something when i seen this and that its old...... boo for me
hate to bring up an old thread but my fuel pressure reads the same. and i have the same gauge. 50 key on, 45 engine running, because i still have a FMU with my supercharger kit im seeing over 100 psi at full boost!
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
