f-ing wireing need help
Old Oct 8, 2010 | 05:13 PM
MISTERIO's Avatar
Default f-ing wireing need help
well i got some 2007 chevy e-fans on my 2001 gmc an i have always had problems with the wireing harness.. i 1st got he nelson performance wireing harnees for the fans an one of the relays melted down so i said **** let me try black bears wire ing harness an today my truck got over heated an check the fans an they were of so i look an the relays an same problem, one of the relays melted down,,, i am just wanna get them to work good btw i only had like 4 months with the harness.... can u guys help me
Old Oct 8, 2010 | 08:52 PM
Swerve7rpm2000's Avatar
First of all u need to know the amperage of both fans and make sure your relays and wire size will handle that amperage, most of the time when **** burns up its because wire size or it improperly wired to the relay, maybe someone on here can give u a schematic on wire size per amps.... gl
Old Oct 8, 2010 | 08:54 PM
Atomic's Avatar
I have a gauge for that
interesting, what size wire are you using?
Old Oct 9, 2010 | 02:09 PM
MISTERIO's Avatar
I dont know what size it the one it came with
Old Oct 10, 2010 | 06:51 PM
MISTERIO's Avatar
So what do i change to a more apm relay an biger wire ? Cuz it melting were it hooks up to one of the relays
Old Oct 10, 2010 | 06:56 PM
well find out how many amps per fan first, i had two fans and both of them were on a single 30 amp relay, 10 gauge wire should be good for this..... this is what i used maybe someone else can chime in
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
